7916 Expansion Module not working.
Answered Question
Jun 23rd, 2008
Hey all, we have a 7975 with a 7916 module. We upgraded our CM 5.1 code to support the module and it see's it, we select it on the device.
The expansion module shows numbers from 1-14 for SD but if you enter anything after SD 14 it's called "abriviated dialing" which is not what we want. I enter a number into slot 15 and it doesn't show up on button 15 on the phone. It seems there isn't enough speed dials for the module on the phone configuration, any ideas?
Correct Answer by Rob Huffman about 8 years 11 months ago
Hi Chris,
Have a look at the Phone Button Template for the 7975. If you find the default Button Template you can Copy it/rename it (something like 7975with7916)and reconfigure it with the appropriate Speed Dial Buttons. Once this has been done go back to the phone/device in question and apply this new Phone Button Template> Update> then go to add/update Speed Dials and you will see all the keys available :)
Hope this helps!
Rob
Overall Rating: 5 (5 ratings)
Correct Answer
Rob Huffman Mon, 06/23/2008 - 12:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chris,
Hope this helps!
Rob
cshannahan Mon, 06/23/2008 - 12:07
I have created a new template. I select the speed dials and I can only do 13 speed dials, then it lists the rest as Abbreviated Dial Settings.
Can all the buttons on the 7916 be speed dials?
cshannahan Mon, 06/23/2008 - 12:17
Wait, I see what you mean now, there was a template created but it was an individial one, I created another one and added all the speed dials, tanks.
Rob Huffman Mon, 06/23/2008 - 15:02
  • Hall of Fame,
    Founding Member
Hi Julio,
Yes, you do need to indicate 1 or 2 Expansion Modules to go along with the Phone Button Template :)
Hope this helps!
Rob
blackmichael Wed, 07/16/2008 - 07:14
I had this issue with CM 6.1. I soloved by loading the latest phone load for the 7965/7975 phone. The problem was not with the 7916 phone load it was the phone's phone load.
mattcalderon Wed, 07/16/2008 - 09:54
  • Silver, 250 points or more
I just ran into the same issue. Running 6.1.2 with a 7965 with a 7916 expansion module. I had to update the phone load to 8-3-5 and the module load to B016-1-0-2.SBN to work with the 7965 on this version of UCM.
The 1.0(2) version of 7915,7916 firmware should be used when your Cisco IP Phone is using the version listed below:
Cisco IP Phone Model
7962, 7965, and 7975
Version
8.3(5) and later
From this link:
http://www.cisco.com/web/software/282074289/18600/cmterm-7915_7916.1-0-2-readme.html
johnnygdrive Thu, 01/15/2009 - 05:58
Having a similar issue here with a expansion module 7916 and IP phone 7975, but I have uploaded the most recent firmware.
Issue I am having is that the expansion module lights are all solid amber, I have added a new phone template... Not of the next steps... Any Ideas????
J
