Unity 4.xx outbound calls
Jun 23rd, 2008
Hi.
i have a problem, i don't know if it's stupid or not, maybe you can help me.
I tried to configure for the subscriber a "costume key map" so they would be able to dial to the calling number directly from the mailbox (PSTN caller). But that function does not work. The system says: "Invalid selection". This features only works for subscribers but not for an outside caller. What could be the problem, can anyone help me?????
JOGO
Overall Rating: 3 (1 ratings)
jjgoncalves Tue, 06/24/2008 - 00:35
Yes what i did was for the subscribers. When they access the mailbox if there is a message from a PSTN caller, then there should be an option to call that number (dial the caller id string. Tried to configure but that option is not available.
