Xmedius Boardless Fax Server
Answered Question
Jun 23rd, 2008
What has been the experience if any that anyone has had with Xmedius boardless fax server solution with CM 4.3 or higher?
Correct Answer by paolo bevilacqua about 9 years 1 month ago
No problem. Please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Mon, 06/23/2008 - 12:07
  • Hall of Fame,
    Founding Member
Are you using MGCP or H.323 ? If the latter, CM is not even involved at all, voice GW will send fax calls to the server directly and viceversa.
darylpotts Mon, 06/23/2008 - 12:23
This will be a new install so what ever is going to be the most painless. If it is H.323 then H.323. it will be. Thanks for the input. Have you had experience installing this yourself by chance and about how long once you have done one would it take to configure for about 12-15 users?
paolo bevilacqua Mon, 06/23/2008 - 12:28
  • Hall of Fame,
    Founding Member
Sorry, no experience. Was just advising how to take the shortest path.
Note if you get a cisco CUE instead, it can do fax / vm for each individual with single number, some users like that.
Also the router alone can do fax server, in the simplest form it will send an email each time a fax is received. Nice because it's free.
Correct Answer
paolo bevilacqua Mon, 06/23/2008 - 12:44
  • Hall of Fame,
    Founding Member
thisisshanky Mon, 06/23/2008 - 13:29
  • Purple, 4500 points or more
Xmedius is a great product. We have used it very all versions of Callmanager. The Xmedius server can be added as a H323 gateway in Callmanager and then you can setup your pstn gateways as h323 or Mgcp gateways as preferred. If your PSTN gateway is H323 based, then you can simply point the Xmedius to go straight to the PSTN gateway, bypassing the Callmanager.
