06-23-2008 12:08 PM - edited 03-15-2019 11:27 AM
I have a site that recently was converted from CM 3.x to 4.2.3. When we upgraded we also started making them dial a "9" for an outside line to make them standard with the rest of our offices. For some reason the users are calling 911 3-4 times a day. They are claiming they are dialing 91815-xxx-xxxx and the phone is dropping the "8", ignoring the rest of the digits and dialing 911. Has anyone ever had a symptom like this?
Solved! Go to Solution.
06-23-2008 10:17 PM
hi
i would just suggest you to have more specific route pattern configured for 911 and for others like 9.!
Else it would be advisable to change the access code to 0 for other calls.
regards
kumar
06-23-2008 06:35 PM
MGCP? H323?
you would need to look at a CUCM trace to confirm they're not dialing 911 by error
only thing i can think of it that the phones are at a remote location and you have network issues that could cause the SCCP message from the key press to not reach CUCM
javalenc
if this helps, please rate
06-23-2008 10:17 PM
hi
regards
kumar
06-24-2008 08:17 AM
Thanks for the advice. After some research i discovered that one of the route patterns was dialing 911 even if they typed additional digits. People were accidentally typing 9118XX instead of 918XXX and the system would dial 911 and disregard the remaining digits. I fixed the route pattern. Thanks for the input.
