Correct Answer
Collin Clark Mon, 06/23/2008 - 12:33
2950 no, but the 3550 can with the Advanced IP image.
Hope that helps.
jason-calbert_2 Mon, 06/23/2008 - 12:34
Can you tell me if any other switches can run layer 3 with the correct IOS. Thanks
Jason
Jon Marshall Mon, 06/23/2008 - 12:34
Jason
2950 - No, it is layer 2 only.
3550 - yes this is a layer 3 switch. The base image supports static routing + RIP. The advanced image supports EIGRP/OSPF etc.
Jon
