Brazil R2-digital configuration
denyshidaka
Hi need to implement CUCM with PSTN gateway to Brasil Telecom in Parana Brazil.
Has anyone done a ideal configuration to their R2?
Can some one send the config??
paolo bevilacqua
Hi, if you search the forum with the form on the right, you can find few threads about E1 R2 in Brazil.
dsobrinho
Level 9
Level 9
Hey man,
Following the configuration for Brazil.
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country brazil use-defaults
  metering
  category 2
  answer-signal group-b 1
voice-port 0/0/0:0
disc_pi_off
timeouts interdigit 0
timeouts call-disconnect 0
I know that you have been done this many times, but following the correct configuration.
best regards my friend.
Daniel Sobrinho
