Offramp unable to FAX Tif file
Jun 23rd, 2008
Configured fax on/off-ramp on 3725 router.
fax----(pstn)---(fxo)3725-----mailserver/client hosted on one pc.
Client is outlook express and quick n' easy mail server.
Onramp works perfectly.
However Offramp is having a problem with faxing the tif file attached. The only thing we get is the email coverpage/header and no faxed graphics.
I had this setup working before (just on different pc) but now it doesn't.
Used lotus notes client/server and outlookexpress client with same output.
version:c3725-adventerprisek9-mz.124-19b.bin
128MB flash
256MB ram
configs:
ip domain name test.net
ip host testmail.com 172.20.136.1
ip host pstnsw.test.net 172.20.136.32
fax send transmitting-subscriber $s$
fax send left-header $t$
fax send center-header $s$
fax send right-header $p$
fax send coverpage enable
fax send coverpage show-detail
fax send coverpage comment FAX test Offramp Cover Page
fax interface-type fax-mail
mta send server 172.20.136.1 port 25
mta send subject Incoming Fax Received
mta send postmaster [email protected]
mta send mail-from username $s$
mta receive aliases pstnsw.test.net
mta receive aliases 172.20.136.1
mta receive maximum-recipients 10
mta receive generate permanent-error
application
service offramp flash:app_faxmail_offramp.2.0.1.1.tcl
service onramp flash:app_fax_detect.2.1.2.2.tcl
param account-id-method gateway
param mode default-fax
param voice-dtmf 1
param prompt flash:en_default_fax.au
param fax-dtmf 2
interface FastEthernet0/0
ip address 172.20.136.32 255.255.255.0
duplex auto
speed auto
voice-port 2/0/0
connection plar 666
dial-peer voice 666 pots
service onramp
incoming called-number 666
direct-inward-dial
port 2/0/0
dial-peer voice 667 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 666
information-type fax
session target mailto:[email protected]
dial-peer voice 668 pots
destination-pattern 8777777
port 2/0/0
forward-digits all
dial-peer voice 669 mmoip
description Offramp inbound service offramp
incoming called-number 8777777
dsn delayed
dsn success
dsn failure
Two things i am wondering if this caused the problem from the debug fax mta all:
*Mar 2 06:37:50.955: //-1/D50B9C44800B/SMTPS/esmtp_server_engine_dot_check:
Not found the terminating Dot!
and...
*Mar 2 06:38:35.955: //-1/D50B9C44800B/SMTPS/rejectMessage:
context(0x64F1D498),
mime: Total=7, Rejected=1, Ignored=3
Any ideas what the meaning of this debug?
I am starting to guess that it maybe a dsp problem.
Any hints? Any configuration that i miss?
Jeff
ivillegas Fri, 06/27/2008 - 02:53
  • Silver, 250 points or more
http://www.cisco.com/en/US/tech/tk652/tk777/technologies_tech_note09186a00801fe5dc.shtml
Add the command to the gateway “no dial-peer outbound status-check pots" as this problem appears to be a configuration issue.
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t5/feature/guide/dtfaxrly.html
Offramp is only supported IP to pots. For offramp tiff comes in on email then need to be converted to faxtone, gateway sets up as locally attached fax machine to terminating fax doing t.30, this is only possible terminating to an outbound pots peer.
jechoi Mon, 06/30/2008 - 05:31
Added the "no dial-peer outbound status-check pots" but didn't solve the issue.
I had similar setup with this but thru E1 instead of fxo which is working.
This config was also working before i deployed it on client site as demo. But for unknown reason, this problem was encountered.
Changed the FXO and NM module but same problem.
Any ideas?
TIA
