6506 Core Switch Port got in Errordisable again and again .............
Jun 23rd, 2008
Dear Folks,
We had old 3500 Series Switches which we have replaced last week with 2960 48 Port ehternet and 2 Gigabit Port with SFP Module.
Now I am facing the problem : The Port of CORE SW to which my one of 2960 SW is connected got in to errordisable. UDLD is enable on CORe as well UDLD enable aggressively on 2960 Gi0/1.
It's understandable that port was being errordisable if unidirectional link is there but the same link is working previously with 3500 Series SW?
Than IS there any other reason for errordisable or something need to change on 2960 SW.
2960 SW basic Config :
config terminal
username -------- password .........
enable secret ...........
enable password .......
service password-encryption
spanning-tree portfast bpduguard
int range fa0/1 - 48
exit
vtp mode transparent
vtp mode client
vtp domain RILHZ
clock timezone GMT 5 30
ntp server 10.2.202.52
int range gi0/1 - 2
switchport mode trunk
udld port aggressive
int vlan 1
ip address x.x.x.x y.y.y.y
exit
line vty 0 4
password ..........
no login
login local
exit
Pls suggest me ..... soon or how to troubleshoot it........???
n.nandrekar Mon, 06/23/2008 - 21:54
  • Silver, 250 points or more
hi!
Can you look at the portfast / bpdu guard configs on both sides of the link that is going to errdisable? Portfast with bpduguard can take down a link (err disable it) if a bpdu is received on that port. Please check that portfast & bpduguard is not configured on the link between the 2900 and core switch on either side.
Niranjan
(pls rate helpful posts)
Dipesh Patel Tue, 06/24/2008 - 19:42
Dear Sir,
Portfast bpduguard by default is enable globaly on 2960 Sw but portfast is not enable on gi0/1 and gi0/2 Fiber port on 2960 sw.
Surya Dathan Thu, 06/26/2008 - 00:23
Note that your config udld aggressive mode in 2960, so, how about other switch side, is it under aggressive mode also? Make sure the same mode is using at both side.
If so, it might be fiber strands in the cable is disconnected or just simply change a new cable to test.
By default, Port Fast is disabled on all interfaces @ 2960 Switch.
Hope this help. Thanks.
Dipesh Patel Thu, 06/26/2008 - 01:34
Dear Sir,
My other end is 6506 L3 Switch with Cat OS and in it we have configured udld on all port i.e.
#udld
set udld enable
#module 1 : 2-port 1000BaseX Supervisor
set port trap 1/1-2 enable
set udld enable 1/1-2
set trunk 1/1 on dot1q 1-1005,1025-4094
set trunk 1/2 on dot1q 1-1005,1025-4094
set port channel 1/1-2 mode on
#module 2 : 2-port 1000BaseX Supervisor
set port trap 2/1-2 enable
set trunk 2/1 on dot1q 1-1005,1025-4094
set trunk 2/2 on dot1q 1-1005,1025-4094
set port channel 2/1-2 mode on
#module 3 : 16-port 1000BaseX Ethernet
set port trap 3/1-16 enable
set trunk 3/1 on dot1q 1-1005,1025-4094
set trunk 3/2 on dot1q 1-1005,1025-4094
set trunk 3/3 on dot1q 1-1005,1025-4094
set trunk 3/4 on dot1q 1-1005,1025-4094
set trunk 3/5 on dot1q 1-1005,1025-4094
set trunk 3/6 on dot1q 1-1005,1025-4094
set trunk 3/7 on dot1q 1-1005,1025-4094
set trunk 3/8 on dot1q 1-1005,1025-4094
set trunk 3/9 on dot1q 1-1005,1025-4094
set trunk 3/10 on dot1q 1-1005,1025-4094
set trunk 3/11 on dot1q 1-1005,1025-4094
set trunk 3/12 on dot1q 1-1005,1025-4094
set trunk 3/13 on dot1q 1-1005,1025-4094
set trunk 3/14 on dot1q 1-1005,1025-4094
set trunk 3/15 on dot1q 1-1005,1025-4094
set trunk 3/16 on dot1q 1-1005,1025-4094
set spantree portcost 3/1 3
#module 4 empty
#module 5 : 16-port 1000BaseX Ethernet
set port trap 5/1-16 enable
set udld enable 5/3-4,5/6-7
set trunk 5/1 on dot1q 1-1005,1025-4094
set trunk 5/2 on dot1q 1-1005,1025-4094
set trunk 5/3 on dot1q 1-1005,1025-4094
set trunk 5/4 on dot1q 1-1005,1025-4094
set trunk 5/15 on dot1q 1-1005,1025-4094
The Above is configuration for UDLD on Core SW.
On 2960 UDLD is enabled only on gi0/1 and gi0/2 Port in aggressive mode.
Portfast is enable on all port fa0/1 - 48
portfastbpdugurd is enable default mode i.e globally.
FO cable is same as before when old 3500 series SW is working. But after migrating sw i.e 2960 this proble occurs.
And avg response of all 2960 sw is also slow now.
So pls suggest me the solution.
If u need any data from me pls .....
