WAAS / WAFS and hidden shares
Answered Question
Jun 23rd, 2008
It may be a strange question but can I preposition hidden shares on a WAAS device? I have tried manually entering in the share name in the "root share and directories" part of a preposition directive in the format /sharename$/
It seems that the preposition copies the files into the WAE's CIFS cache, but once I do that I can't access the files in the hidden share anymore.
My other question is once I preposition some files to my WAE is there a way that I can selectively delete items from the CIFS cache (I am thinking of deleting the files in that particular share if possible as a troubleshooting step).
Peter
Correct Answer by Zach Seils about 8 years 6 months ago
Peter,
Yes, WAAS will pre-position hidden shares. Can you please elaborate on not being able to access the share after pre-position?
To your second question, there is currently no way to delete specific files from the CIFS object cache (other than deleting the file on the origin file server (from a session through the WAFS Edge).
Zach
Overall Rating: 5 (2 ratings)
Correct Answer
Zach Seils Fri, 06/27/2008 - 02:15
Peter,
Zach
pthaynes Fri, 06/27/2008 - 02:39
Zach,
The files in the hidden share that we pre-positioned were for SMS packages. Once we pre-positioned them we were no longer able to deploy those packages to clients. I am a little suspicious that the real issue is with SMS - not the files themselves.
On the subject of deleting specific files in the CIFS object cache - is there any way to actually SEE the files that are in the cache, rather than deleting them?
Thanks for your help.
Peter
