sup720
Jun 23rd, 2008
Dear all
I want to use sup720 with maximum throughtput, but when I looked into SUP720 datasheet,it was "DFC required"
my question is that how should I use DFC.
I want to select sup720-3bxl to achive
(400mpps)
regards
Overall Rating: 5 (1 ratings)
n.nandrekar Tue, 06/24/2008 - 00:09
  • Silver, 250 points or more
hi!
The "DFC required" condition means that the linecard that you are using for the traffic should be equipped with a DFC. A DFC is a distributed forwarding engine which sits on the linecards and maintains tables (like mac-table, CEF etc) on the Linecard so that the decision can be made locally for the traffic and doesnot have to be sent to the sup.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_qanda_item09186a00809a7673.shtml
Above is a link for more info.
So the requirement states that a DFC equipped linecards are required to achieve that performance level.
Niranjan
(pls rate helpful posts)
