Analog modem and VoIP
Answered Question
Hello -
We have an analog modem that we need to connect to our CCM 6.x solution. I read the ATA 186s don't support it. Do we need to use an FXS card in the router instead?
Correct Answer by Paolo Bevilacqua about 8 years 9 months ago
With ATA, the modem would work up to moderate speeds only, and require a perfect IP network.
An FXS port in the router doesn't have any limitation and is a much better solution.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Mon, 06/23/2008 - 23:17
  • Hall of Fame,
    Founding Member
Paolo Bevilacqua Thu, 06/26/2008 - 02:24
  • Hall of Fame,
    Founding Member
Do you have E1 ot T1 in the router? If so you might be missing the necessary "network-clock-select" command.
Paolo Bevilacqua Thu, 06/26/2008 - 09:34
  • Hall of Fame,
    Founding Member
Check anyway "show controllers T1" for any slips. If none, search "troubleshooting ata fax" and configure the ata accordingly to the document.
