VM4.x Upgrade to CUCM 6.01 BE
Jun 23rd, 2008
we try to upgrade to CUCM 6.01 BE on a new Hardware. During the Installation of the BE there is no Option to Import Files from a previous CM Version.
Is it possible to upgrade from CM4.x to CUCM 6.x BE ?????
If its possible, how ???
In the Installation Guides of the CUCM BE there is no description of the upgrade path.
Thanks for Help
rob.huffman Tue, 06/24/2008 - 04:53
Hi Ralf,
You won't love this answer, but I thought it might help anyways :)
The Cisco Unified Communications Manager Business Edition offering is for new installations only.There is no migration to or from the Cisco Unified Communications Manager Business Edition.
That being said, you can try using the BAT Export from CCM 4.x and use the data to build the phone/user config in BE. The files won't match exactly so you would have to play with the formatting.
Hope this helps!
