Router support 8 Mbps encryption VPN tunnel
Answered Question
Jun 24th, 2008
Please suggest me the Cisco router which support 8 Mbps encryption VPN tunnel for site to site VPN.
Customer having MPLS connectivity on both the sites
Awaiting for your response.
Manoj
Correct Answer by paolo bevilacqua about 9 years 1 month ago
According to cisco, an 87x is good for up to 30mbps of cyphered traffic:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps7180/prod_brochure09186a00801f0a72_ns171_Networking_Solutions_Brochure.html
The tunnel limits are also listed in the above document.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
Overall Rating: 5 (3 ratings)
paolo bevilacqua Tue, 06/24/2008 - 00:48
  • Hall of Fame,
    Founding Member
Hi, any current model would do, eg 87x, 18xx,
etc.
a.alekseev Tue, 06/24/2008 - 07:17
  • Gold, 750 points or more
I'm not sure that 8XX 18XX is good enough.
Many services on a router will eat CPU.
So, I would suppose 2811 and higher
manojdubey02 Tue, 06/24/2008 - 20:18
Dear Collin,
Is there any user limination for VPN access concurrently (IPSec) if go with 1841 with AIM-VPN/SSL-1 ?
Manoj
Collin Clark Wed, 06/25/2008 - 05:21
  • Purple, 4500 points or more
I don't believe there is a tunnel limit (Cisco leans towards tunnel limits instead of user limits).
Correct Answer
paolo bevilacqua Wed, 06/25/2008 - 05:27
  • Hall of Fame,
    Founding Member
