VG224 with Bulk "feature or method not supported"
Jun 24th, 2008
Im tring to add some VG224 SCCP gateways via Excel Bat Tool. I Can Create the file format and everything is fine until Im tring to export the Data to BAT file format.
There is an error message: feature or method not supported
I tried it with other devices and it works fine. Only the VG224 doesnt work. What am I doing wrong?
Rob Huffman Tue, 06/24/2008 - 04:17
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mohamed,
If you are running a 6.x version of CCM, which I'm guessing you are, you are likely hitting the Bug referred to by Brent in this recent post.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1009e/2#selected_message
Hope this helps!
Rob
Mohamed Ibrahim Tue, 06/24/2008 - 05:29
Thank you I found out, that it works fine with the 6.0 Bat.xls file. But in the Job Scheduler I still get: "Could not insert new row - duplicate value in a UNIQUE INDEX column"
