Client VPN routing problem
Answered Question
Jun 24th, 2008
I am trying to setup vpn client software ver 5.0 for remote users to connect to the lan behind an 1801.
I can get the client saying its connected but traffic doesn't flow apart from:
when i try to ping a 192.168.2.x address behind the 1801 i get a response from the public ip but then when i try to ping another address i get no response.
I am assuming that the issue is NAT related.
Below is my config, your help is apprecited
service password-encryption
hostname C######
boot-start-marker
boot-end-marker
enable password 7 #######
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
ip cef
ip domain name ######.local
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username admin privilege 15 password 7 ########
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group 1801Client
key ##############
dns 192.168.2.251
wins 192.168.2.251
domain #######.local
pool VpnPool
acl 121
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address initiate
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
archive
log config
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
ip address 87.#.#.# 255.255.255.252
ip access-group 113 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet8
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
ip address 192.168.2.245 255.255.255.0
ip nat inside
ip local pool VpnPool 192.168.3.200 192.168.3.210
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 87.#.#.#
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source static tcp 192.168.2.251 25 87.#.#.# 25 extendable
Several similar to above line with diferent ports
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 113 permit tcp host 82.#.#.# host 87.#.#.# eq 22
access-list 113 permit tcp 84.#.#.# 0.0.0.3 host 87.#.#.# eq 22
access-list 113 permit tcp host 79.#.#.# host 87.#.#.# eq 22
access-list 113 deny tcp any any eq 22
access-list 113 permit tcp host 82.#.#.# host 87.#.#.# eq telnet
access-list 113 permit tcp 84.#.#.# 0.0.0.3 host 87.#.#.# eq telnet
access-list 113 permit tcp host 79.#.#.# host 87.#.#.# eq telnet
access-list 113 deny tcp any any eq telnet
access-list 113 permit ip any any
access-list 121 permit ip 192.168.2.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 121 permit ip 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
transport input telnet ssh
end
Correct Answer by michael.leblanc about 8 years 7 months ago
You have more than just a NAT issue.
reverse-route
Note: Reverse-route injection needed to provision a return path.
Note: The second ACE in the split-tunneling ACL is unnecessary.
Correct Answer by Marwan ALshawi about 8 years 7 months ago
you need to exmpt the client pool IP address from the NAT
by either denying them in access list 1
or make route map that point to loopback address as a next hop for any packet destent to your pool to avoid the nat
first try to put this entry in your access-lst 110
access-list 110 deny 192.168.2.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 110 permit 192.168.2.0 0.0.0.255 any
route-map nonat pemit 10
match ip address 110
remove ur old nat and put the following one
ip nat inside source route-map nonat interface fastethernet0 overload
rate if helpful
and let me know, good luck
Overall Rating: 5 (2 ratings)
Correct Answer
Marwan ALshawi Tue, 06/24/2008 - 04:15
rate if helpful
IainTrade Tue, 06/24/2008 - 09:08
Thank you very much for your help, really appreciated the fast responses.
Cheers Gents.
Correct Answer
michael.leblanc Tue, 06/24/2008 - 07:31
reverse-route
