Can't make calls with video dial-peer
Jun 24th, 2008
I want to establish videoconferences using a cisco 7985 against an external system. At first I thought that I had problems with numbers that belonged to video peers, but then I realized that it was the same with normal peers, but always that I used this dial-peer.
The dial-peer that I'm using is:
dial-peer voice 100 pots
destination-pattern 70.%
information-type video
incoming called-number 91732XXXX
bandwidth maximum 128 minimum 128
port 0/0/1:15
forward-digits 9
dial-peer voice 101 voip
voice-class codec 2
session target ipv4:10.252.a.b
incoming called-number 7091837YYYY
When the call is made, it shows this disconnection cause:
Jun 23 18:23:43.539: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0043
Cause i = 0x80AF - Resource unavailable, unspecified
Display i = 'RECURSOS NO DISPONIBLES'
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
If followed a guide to configure this dial-peer, but obviously I did something wrong. I think it may be related with the primary and secondary channels, but I'm not really sure how to configure them.
Any idea it could work?? I will appreciate any kind of help. I attach the configuration file and a trace file. Thank you very much.
Marwan ALshawi Tue, 06/24/2008 - 21:04
i think you have to put the bandiwdith duble
for example u have put it like 128 try to make it 256
also if you have deffrent codec in use check XCODING resources
good luck
Chad Stachowicz Tue, 06/24/2008 - 21:27
for Voice, XCODER resources will not be invoked using voice-class codec X.
Dial-peers must be set hard! (i.e. codec g711ulaw)..
Chad
luz.mata Wed, 06/25/2008 - 06:47
I am working on the same issue and I have upgraded the bandwith to 256 kbps, removed the voice-class codec from the dial-peer and established codec g77ulaw as the unique codec, but it is still not working. Any other idea that we could try??
Thank you very much!!!
luz.mata Wed, 06/25/2008 - 07:06
Now the dial-peers are this way:
incoming called-number 917328040
bandwidth maximum 256 minimum 256
port 0/0/1:15
forward-digits 9
session target ipv4:10.252.100.11
incoming called-number 70918379060
codec g711ulaw
Alberto
