06-24-2008 02:48 AM - edited 07-03-2021 04:04 PM
Is there such thing as a Cisco .11n wifi adapter?
Is there a USB Cisco wifi adpater?
Is there a PCI Express Cisco wifi adapter?
If the AP is 11n, are the b/g wifi cards still gonna work? Are the 11n AP's backward compatible with the b/g wifi adapters?
Thanks for any ideas.
Solved! Go to Solution.
06-24-2008 03:36 AM
Here is what I know. Hope it helps.
No. Cisco is working along side Intel to standardize on the draft 2.0. Cisco is out of the wifi card business.
No.
i think they use to make one, unless it is not the PCIe.
Yes they are backwards compatible with a/b/g. Just make sure your drivers are up to date.
06-24-2008 03:36 AM
No.
06-24-2008 07:53 AM
thanks, fella5!!
07-14-2008 05:14 AM
For Info, I was looking for the same and got the same answers from Cisco.
I bought 2 a/b/g/n (Draft 2.0) Client cards from Airmagnet in the end, so That I can survey using Using that standard.
07-14-2008 05:21 AM
Not a standard yet.... hopefully it doesn't change too much:)
07-16-2008 10:52 PM
unfortunately, our new laptops don't come with the pcimcia slots. i think they're called pci express now, where the interface part of the card is chopped in half. so, i'm left with usb, internal and the pci express for wifi slots. there are other compatible cards in the airmagnet website either usb or pci express that i will have to check if they will go with our new laptops.
