Black console
Jun 24th, 2008
I try to setup a Cisco device, so i connect the engine to my serial port.
In my console i got some message like %SYS-5-CONFIG_I: Configured from console by cisco on vty0 (, and not the prompt router>.
Thanks in advance,
mezgani.ali Tue, 06/24/2008 - 23:46
Yes, i pressed Enter key lot of times, also i could not have the prompt.
mezgani.ali Thu, 06/26/2008 - 09:15
It's resolved i got a message Press RETURN to get started. after that the console ask for a username and password, i entered cisco/cisco, the console reply yourname con0 is now available.
The problem is that i can not be logged into the system with cisco/cisco.
