Newbie needs help with his ASA 5510
Jun 24th, 2008
I'm not a networking person at all and don't know where to look. We have an ASA 5510 and I want to see who is streaming video and surfing unmentionable sites. Once I find out who and where they are going, I eventually want to block those sites. We are a small 60 employee company and that T1 is DOG slow at times. Can the ASA 5510 help me with want I want to do? If not, are there any cheap solutions?
Quin
dhananjoy chowdhury Wed, 06/25/2008 - 00:06
Yes, you will have to go through the logs and find the IP address/ domain names/url's/ ports where the users are connecting to..
Then you can -
- block the IP's/ports using access-lists
- block the domains/urls with specific expression like "xyz.com" or ".mp3" using regular expressions
quinfilipowicz Wed, 06/25/2008 - 05:41
Isn't there a way to see the NAMES of the domains? I don't want to have to sort through IP addresses to see which ones are legit. If not, is there a software package out there that reads this information and converts the IP addresses into Domain Names?
Quin
jcadmin Thu, 10/02/2008 - 08:40
You might want to consider adding a specific web access tracking product like Websense. It can filter and block sites by category and log access. It is compatible with ASA.
This will save you a lot of log file diving. There are enough inappropriate sites out there that when you block them manually you might never finish.
