ASA With AnyConnect VPN Issues
Jun 24th, 2008
I am trying to setup a VPN on this ASA using AnyConnect. I was able to get the IPSec VPN to work but we have to use AnyConnect for Vista support. I have the VPN part working to where clients can establish a VPN connection. The problem is that they cannot do anything from that point on. I think (am guessing) there is an issue with the return address translation, where the machine behind the firewall cannot properly communicate with a machine that is on the VPN. I have attached the running-config and was hoping someone could point me in the right direction. Here is an example of an error I am getting:
No translation group found for udp src outside:10.10.10.101/137 dst inside:10.10.10.255/137
Thanks.
Fernando_Meza Tue, 07/01/2008 - 03:31
  • Gold, 750 points or more
try enabling nat-traversal. At the moment it is disabled on your configuration
"no crypto isakmp nat-traversal"
from config mode type in as below and test it again.
crypto isakmp nat-traversal 20
