Cisco call manager 6.0
Answered Question
Jun 24th, 2008
I am using VMWare console and I had installed the Red Hat for using it with Cisco Call Manager 6.0.
I can login in the application but, when I try to open the web page with the webbrowser I can not login and the page cannot be displayed.
Please check the attachments.
Thank you and regards.
Urban.
Correct Answer by thisisshanky about 8 years 7 months ago
I am glad that works for you!!..thanks for the 5!!
Can you avoid the proxy ?
You can set this in the browser and say for local subnets, bypass the proxy and add the subnet 10.10.10.* (assuming your callmanager subnet is 10.10.10.x)
Overall Rating: 4.3 (3 ratings)
thisisshanky Tue, 06/24/2008 - 07:55
Redhat is installed as part of CM 6.0 install. Did the install complete ? Your VMware config for network settings should be set to bridge through the PC nic card. The IP address of teh Vmware should also fall in same subnet as the active interface of the PC nic.
Urban_Nights Tue, 06/24/2008 - 08:01
thank you for your feedback.
Yes, the installation was finished.
I saw that according to the network everything is fine, because when I had an error related with the network connection the installation was stopped and just only when the network settings were verified the installation was concluded.
What else could be?
With regards and thanks for your efforts.
Urban_Nights Tue, 06/24/2008 - 08:13
I reserved about 40G for Virtual HDD.
Is this enough?
I will try to see if the commands can help me.
Thank you for your efforts.
Urban_Nights Tue, 06/24/2008 - 08:53
The thing is that when the CuCm starts it says that VMWare is not a supported platform...
Any ideas?
With regards and thanks.
thisisshanky Tue, 06/24/2008 - 08:55
Thats just to inform you that this is not a tac supported way of installing CM. YOu can use it in lab environments.
Are all the services up and running? especially web, tomcat..
Zin.Karzazi Tue, 06/24/2008 - 08:56
I have CCM 6.0 up and running on my VMWare Server with 1gb RAM and 30gb HDD. No problem at all.
The message you saw is normal, you just click proceed and install your CCM.
did you try restarting web services as earlier suggested?
Zin.Karzazi Tue, 06/24/2008 - 08:59
Are you using some proxy? check you Internet Explorer see if any proxy server is activated
Urban_Nights Tue, 06/24/2008 - 09:12
Thank you for your efforts!
Yes, the proxy is the same.
I restarted the system and have the same result.
I did show web-security and I can see the same certificate.
Maybe I should see if all services are up.
Correct Answer
thisisshanky Tue, 06/24/2008 - 09:53
Urban_Nights Tue, 06/24/2008 - 10:11
You are the best!
Thank you, you solved my issue!
I bypass for local addresses, and I am add the subnet 10.11.*.* (255.255.0.0)
Thank you, thank you so much.
With best regards and thanks once more,
Bruno.
