Aironet Authentication Question
Jun 24th, 2008
I have an Aironet 1130AG Series Access Point and would like to do the following:
When users connect to the access point, a Web page opens asking for a user name and security code. Users can only access the Internet after correctly authenticating.
Can this be done with the Aironet 1130AG?
Thanks for any help.
-Avery
Scott Fella Tue, 06/24/2008 - 09:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If you have an autonomous 1130AG, you will need to implement a portal of some sort like ZoneCD. If you have a WLC and the 1130AG is Lightweight, then you can use the guest access webauth page. Hope this helps.
rseals Tue, 06/24/2008 - 14:13
When we had an autonomous network we used m0n0wall as a guest portal. It worked very well and was opensource.
Georgios Nikitas Wed, 06/25/2008 - 04:50
The Aironet 1130AG cannot do this.
You will have to use a separate program like the ones mentioned before to do this.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
