NAT in Transition
Jun 24th, 2008
3640 router version 12.3
We have most of our machines on a class C network. We have a DMZ setup with static NAT addresses. We are running low on the class C network IP addresses so would like to transition to NAT overload (PAT).
The commands I am using are:
ip nat pool ptinat 198.17.220.118 198.17.220.118 netmask 255.255.255.0
ip nat inside source list 20 pool ptinat overload
access-list 20 permit 172.28.0.0 0.0.255.255
I also put the following on the interface FastEthernet0/0
ip address 198.17.220.118 255.255.255.0 secondary
Once I have done this the 198.17.220.0 and the 172.28.0.0 networks cannot talk to each other.
Any ideas?
a.alekseev Tue, 06/24/2008 - 11:27
  • Gold, 750 points or more
the 198.17.220.0 and the 172.28.0.0 networks cannot talk to each other because you did PAT.
Only hosts from 172.28.0.0 can have an access to hosts in 198.17.220.0.
lnatschke Tue, 06/24/2008 - 11:47
I am logged into the 172.28.0.0 host.
If I ping 198.17.220.0 host it is successful
If I traceroute 198.17.220.0 host it is succesfull
If I ssh to 198.17.220.0 host, it comes back with:
debug1: Connecting to 198.17.220.131 [198.17.220.131] port 22.
debug1: Connection established.
debug1: identity file /root/.ssh/identity type -1
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_dsa type -1
ssh_exchange_identification: read: Connection reset by peer
If I turn NAT off, I can this same ssh will be successful.
I am grateful for any help you can give me.
Thank you.
a.alekseev Tue, 06/24/2008 - 12:28
Could you show all parts of your config related to NAT/PAT?
lnatschke Tue, 06/24/2008 - 13:02
I am a bit nervous about putting too much of the config out on the network.Does this help at all?
ip address 198.17.x.x 255.255.255.0
ip broadcast-address 198.17.220.255
ip nat outside
interface FastEthernet3/1
description PTI TESTING NAT
ip address 172.28.0.100 255.255.0.0
ip broadcast-address 172.28.0.255
ip nat inside
a.alekseev Tue, 06/24/2008 - 13:20
remove this line from the config
and try again
lnatschke Wed, 06/25/2008 - 06:11
Sorry to say it did not make any difference to have the secondary interface removed.
