ASA VPN connection
Jun 24th, 2008
Hi I have a Cisco ASA 5540 that I have numerous lan-to-lan VPN's. According to one of our IT analysts, they primarily use the tunnel from midnight to 7am. Outside of that time frame they say the tunnel goes down. Should I increase the timeout on my side and ask to increase the timeout on the other end. Currently my end is set to 8hours.
Also would my ASA invalidate TCP/IP packets if the connection has been idle too long?
thanks,
Mike
hadbou Mon, 06/30/2008 - 08:23
  • Bronze, 100 points or more
LAN-to-LAN VPN configurations are between two IPSec security gateways, such as security appliances or other protocol-compliant VPN devices. A LAN-to-LAN VPN connects networks in different geographic locations.
Refer the following url for more info on comfiguring and troubleahooting LAN-to-LAN VPN:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/site2sit.html#wp1002608
