Message Notification SMTP port configuration
Jun 24th, 2008
I am trying to enable Message Notification on Cisco Unity Express, when I am configuring SMTP settings, I can't go on cause my SMTP server is on a different port, is not running on port 25/TCP, is there a way to tell the CUE to connect to a different port??
Juan Carlos Arias
Anonymous (not verified) Mon, 06/30/2008 - 08:25
Port number is not configurable. But there are a few SMTP implementations which does not use the regular port 25 for security reasons.
Refer the bug CSCsi12578.
