Automatic Line Selection for Incoming Calls - Not Working
Jun 24th, 2008
According to Cisco text:
"On multiline IP phones, lifting the handset automatically selects the first ringing line on the phone or, if no line is ringing, selects the first available idle line for outgoing calls. This is the default behavior for all multiline IP phones."
Our phones (7961s) do not do this, when you pick up the handset it selects the first line and you are forced to push the button for the ringing line (if it is not comming in on line 1). Any ideas on what is setup incorrectly?
Any input is greatly appreciated.
Overall Rating: 4.5 (2 ratings)
Rob Huffman Tue, 06/24/2008 - 11:14
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paul,
There is a Setting called "Always Use Prime Line" if this is set to True, the Handset will only pick up calls ringing in on the Prime Line. If it is set to False, picking up the handset will Pickup any ringing call. It sounds like your setup has this set to True.
In order to change this parameter, log in to the Cisco CallManager Administration page and perform these steps:
From the Service menu, choose Service Parameters.
Choose Publisher CallManager Server > Cisco CallManager service.
Under the Clusterwide Parameters (Device - Phone) section, scroll down to the Always Use Prime Line parameter, choose True for this parameter, and click Update.
Note: The default value for the Always Use Prime Line parameter is False. If the flag is set to True, when the phone goes off-hook or the speaker button is pressed, then the primary line is chosen and becomes the active line. If a call comes in on the second line of a user, going off-hook makes only the first line active. In this case, the user must select the second line in order to answer the call. If the flag is set to False, the phone automatically chooses a line as the active line based on the line status.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00800a6763.shtml#q39
Hope this helps!
Rob
pschweisthal Tue, 06/24/2008 - 11:19
That is very helpful, I will give this a go. Thank you much!
