Some FAC calls do not appear in Car Reports
Answered Question
Jun 24th, 2008
I'm running ccm 4.2(3)sr3 with CAR version 4.2(1.021.000), ART version 4.2(0.1). I have FAC configured and it works well, but when using CAR FAC/CMC report , only calls made from specific phones appears in the report. I made calls using diferent FAC from the same phone (whose calls dos not appear), but the situation is the same. This situation is independent of the phone model.
Correct Answer by Jaime Valencia about 8 years 7 months ago
is CDR enabled on all the servers in the cluster?
if it's only enabled on one server then you will get CDR only for that particular server.
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 06/24/2008 - 15:53
javalenc
pedroferreras Tue, 06/24/2008 - 19:33
Hi, is only enabled on the publisher (i have 1 publisher and 1 subscriber) the thing is that with 2 phones registered in the same cluster, one generates cdr an the other dosn't generate any records. Please remember i'm running the CAR FAC/CMC Report.
pedroferreras Wed, 06/25/2008 - 04:30
Hi, i think you're right, i will check the configuration, because i think i did not activate the cdr service parameters on the subscriber server.
Thnaks.
Jaime Valencia Wed, 06/25/2008 - 05:30
good to hear that, that's a best guess but since you mention CDR is only enabled in one server that sounds like the possible issue. phones on the server where CDR is enabled will show up in the reports and phones that are in a server where CDR is not enabled won't show up
javalenc
