vpning in and then asdm or ssh
Jun 24th, 2008
ciscoasa# sh run
: Saved
ASA Version 8.0(2)
hostname ciscoasa
enable password xxx
interface Ethernet0/0
nameif outside
security-level 0
ip address internet_ip
interface Ethernet0/1
nameif inside
security-level 100
ip address
interface Ethernet0/2
no nameif
no security-level
no ip address
interface Ethernet0/3
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address
passwd xxx
ftp mode passive
clock timezone mst -7
access-list split_tunnel_list standard permit
access-list inside_nat0_outbound extended permit ip
access-list outside_access_in extended permit tcp any host internet_ip eq www
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool vpnuserspool mask
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1
static (inside,outside) tcp interface www www netmask
access-group outside_access_in in interface outside
route outside isp_gateway 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http internet_ip_2 outside
http management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh scopy enable
ssh internet_ip_2 outside
ssh timeout 60
console timeout 0
dhcpd address inside
dhcpd dns dns_1 dns_2 interface inside
dhcpd enable inside
dhcpd address management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
enable outside
svc image disk0:/anyconnect-win-2.2.0133-k9.pkg 1
svc enable
group-policy vpnuserspolicy internal
group-policy vpnuserspolicy attributes
vpn-tunnel-protocol svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel_list
address-pools value vpnuserspool
username admin password xxx encrypted privilege 15
username vpnuser1 password xxx encrypted
username vpnuser1 attributes
vpn-group-policy vpnuserspolicy
prompt hostname context
: end
support.edm Tue, 06/24/2008 - 12:24
VPN works. What I want to do is vpning into the device as admin, and then load up ssh or asdm and connect to the device (presumably since that's the inside interface).
I tried:
ssh outside
http outside
but it doesn't work.
smjaggers Tue, 06/24/2008 - 13:02
The best way to do this is to just have a single internal host that can access the SSH/ASDM. Allow RDP(Windows Box) or SSH (*nix box) access to it. This does not give blanket access to a huge range of IP's, much more secure.
But if you do wish to do it the other way, you are going to have to add and entry to your ACL:
access-list outside_access_in extended permit tcp host eq ssh and https
access-list outside_access_in extended permit ip host
You will also need a nat exempt for source destination
hope this helps.
support.edm Wed, 06/25/2008 - 13:44
I did this:
ssh inside
nat (outside) 0 access-list outside_access_in
ssh didn't work. Getting
3 Jun 25 2008 15:46:23 710003 TCP access denied by ACL from to outside:
