a.alekseev Tue, 06/24/2008 - 14:39
you should modify your acl #40 to extended ACL and exclude from NAT all traffic addressed to 192.168.0.85-192.168.0.90
rchoksey Wed, 06/25/2008 - 11:23
Thanks for you help and reply. I made the ACL extended and now I am able to access servers on the network however server that have static ip nat inside source statement, I am not able access those servers on those ports. I not sure whether my acl for excluding traffic from NAT is correct. thanks
a.alekseev Wed, 06/25/2008 - 12:50
I cannot provide you a good solution in this case but I think I can provide you workaround.
on you server add yet another ip address or aliais and use it for access the server.
