AXL Perl Source Offer
Jun 24th, 2008
I just posted this on another thread as a response and thought some might find it as a useful AXL PERL example.
Overall Rating: 4.5 (2 ratings)
pbaustin Tue, 12/09/2008 - 10:18
Hi, I don't want to seem to be too stupid but what exactly do I need to do with this zip file.
dbenattou Fri, 03/06/2009 - 11:41
thanks for the Perl Script.
I have applied, it works but i have issue in Call classification field.So, the content of this field is by default Off-Net.After the apply, it begins On-Net.
My request is to know the name of this Field in the Informix Database to modify it.
Chad Stachowicz Sun, 03/08/2009 - 04:36
go check out the axl schema, you actually just need to add the portion of this into the SOAP request in the script. The XML Schema's can be found in the axlsqltoolkit in CCM plugin's page!
HTH, please rate useful posts.
dbenattou Sun, 03/08/2009 - 19:31
thanks for the link .
it hepled me very much.
Kind Regards
