Traffic Generator
Answered Question
Jun 24th, 2008
Hi all,
I'm after a free RTP traffic generator to do some QOS testing in a home-lab setup.Would prefer a XP based software.Any suggestions?
Correct Answer by andrew.butterworth about 9 years 4 weeks ago
For traffic generation Windows is pretty bad, especially UDP at any decent rates. If you are just after simulating one call then you could quite easily use MS Netmeeting between two PC's and make a G.711 call. Obviously you won't get any decent stats out of Netmeeting but I assume you are using this to test QoS policies on routers or switches?
I would recommend the IP SLA feature in IOS to simulate VoIP and the statistics it generates are very good.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t4/htrtpvip.html
Commercially as a company we use NetIQ Vivinet Assessor with Linux endpoints to test 'Network readiness for VoIP'.
Andy
Overall Rating: 4.3 (3 ratings)
n.nandrekar Tue, 06/24/2008 - 20:02
  • Silver, 250 points or more
hi!
You can use SIPp.
http://sipp.sourceforge.net/
Alternatively you can use VLC media player (videoLan) available freely on the net to send a video file as RTP unicast/multicast on the lan. you can use the same player installed on the other PC as a reciever. Use the wizard in that for configuring the stream to be sent.
http://www.videolan.org/vlc/
Cheers!
Niranjan
(pls rate if helpful)
Correct Answer
andrew.butterworth Wed, 06/25/2008 - 01:47
  • Gold, 750 points or more
Andy
jbest1028 Fri, 06/27/2008 - 11:30
Most devices have a built-in one that generates tcp packets. Run ttcp from enable.
