Achieving Taildrop on Sup720-3BXL with 1p2q2t
Jun 24th, 2008
  • Bronze, 100 points or more
Hi all,
I have a situation whereby I would require to configure a taildrop behavior for queue2. The CoS mapping are as follows:
interface GigabitEthernet5/1
wrr-queue cos-map 2 1 4 !CoS 4>Q2 Low priority/Threshold#1
wrr-queue cos-map 2 2 6 7 !CoS 6,7>Q2 High priority/Threshold#2
Basically Q2 is serving UDP traffic. Native ports of SUP720, PFC3BXL doesn't support "taildrop" command "wrr-queue threshold". If I would still require to achieve taildrop behavior in which frames with CoS4 @Threshold#1 gets taildropped when it reaches 90% and CoS6,7 @Threshold#2 gets taildropped when it reaches 100%, would the following config achieve such behavior:
wrr-queue random-detect max-threshold 2 90 100
wrr-queue random-detect min-threshold 2 90 100
If it was on a WS-X67xx type cards with 1p3q8t taildrop can be achieved with the following:
interface GigabitEthernet1/1
wrr-queue threshold 3 90 100 100 100 100 100 100 100
Appreciate good advice on this.
