How to Hide a some of the lines in the configuration
Jun 24th, 2008
we are using the Cisco ACS 4.2 with TACACS+, in that i created one group which is havig read only access to user. now the problem for me is when ever they are typing the command like "sh run" it is displaying the complete content in my configuration. i just want to hide the some the line which something like SNMP strings, Line vty password. ...etc. Is there is any possibility of doing this.
Overall Rating: 3 (1 ratings)
Jagdeep Gambhir Wed, 06/25/2008 - 05:12
  • Red, 2250 points or more
Using acs you cannot hide some output of any command. Using acs you can set if specific is allowed or not allowed.
YOu can do this using local authorization configured on the router/swtich itself.
For acs you need to set up command authorization. Here is the link,
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
~JG
Do rate helpful posts
