Header Map Question
Answered Question
Jun 24th, 2008
  • Gold, 750 points or more
I have already the following header map which works fine:
match protocol http header Host header-value abc.def.example.com*
Now I need to match whether the subdomain "def" is present or not. So, would the following accomplish this:
match protocol http header Host header-value abc.*example.com*
thanks,
Andrew.
Correct Answer by Gilles Dufour about 8 years 10 months ago
Actually the first one is incorrect.
But it will work.
What you need is this
match protocol http header Host header-value abc\.(def\.)?example\.com
Press -v to insert the '?'
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Wed, 06/25/2008 - 04:53
  • Cisco Employee,
But it will work.
Gilles.
andrew.burns Wed, 06/25/2008 - 06:47
Thanks Gilles,
Some review of regular expressions might be in order ;-)
