Easy VPN issue
Jun 24th, 2008
I'm facing an issue while doing easy VPN with network extension mode.
I have a setup
192.100.100.0/24 ---inside (ASA5510 Central ) outside 80.2XX.1XX.1XX --------dynamic ADSL router 192.168.16.1-----192.168.16.21 outside (ASA5505 remote) inside 192.168.1.0/24
I configured the easy VPN with network extension between the central and remote sites I can see that the VPN is up but I'm unable to ping the LAN IPs from the server and remote client attacing the configs also.Split tunnel is also configured.
I cannot reach to the server LAN(192.100.100.0/24) from the remote(192.168.1.0/24) and Vice versa
nomair_83 Mon, 06/30/2008 - 00:08
  • Bronze, 100 points or more
hi,
your ACL should be like this..
access-list no-nat extended permit ip 192.168.1.0 255.255.255.0 192.100.100.0 255.255.255.0.
and type "no vpnclient enable" on server and also verfiy that sysopt connection permit-ipsec.
just remove nat-traversal from default crypto policy and retype it in isakmp policy 10.
Let see it works
kaachary Mon, 06/30/2008 - 09:14
  • Cisco Employee,
Can you post the output of :
sh cry ipsec sa
sh vpnclient
from the EZvPN client.
