ATA require license ?
Jun 25th, 2008
customer having Call Manager for thier IPT services. He want to use ATA for fax, need to integrate with Call manager (CUCM6-BE).
Please suggest me license option , which is required here. Here i m finding 3 option for license (SW-CCM-UL-ANA, SW-SMH-UL-ATA-1P, SW-CCME-UL-ANA).
Please suggest me the license require for ATA, used for fax.
Manoj
thisisshanky Wed, 06/25/2008 - 04:19
  • Purple, 4500 points or more
Those licenses you listed are for 4.x or 3.x trains of CCM. You will need to get 1 DLU per ATA. You can order LIC-CM-DL-1 (times the number of ATAs)
kalamoodi Wed, 08/26/2009 - 01:32
Using the dynamic configuration tool there is a configuration error & one license should be selected. Can we just ignore the error & add LIC-CM-DL-1 instead.
Rob Huffman Wed, 08/26/2009 - 04:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Khaled ,
Sure, just add one of these per ATA or LIC-CM-DL-10 if you had 10 ATA's. It's always good to have extra licenses moving forward anyways :)
Cheers!
Rob
