a.alekseev Wed, 06/25/2008 - 08:28
According your diagram
192.168.2.11 is in an outside segment
But the same network is attached to pix's inside interface.
so PIX do not support such configurations.
cscisco_admin Wed, 06/25/2008 - 23:28
Thanks very much. This is what i needed to know.
Now if i change pix inside interface IP like 192.168.22.1 then what configuration is needed to allow 192.168.21.11 connect to my Terminal Server on 192.168.21.2 through the mapped public ip of pix.
Thanks!
a.alekseev Thu, 06/26/2008 - 21:34
You need static NAT or PAT and access-list on outside interface that permits connetions to you Terminal Server's piblic ip
