Configuration RSTP and PVSTP +
Jun 25th, 2008
We want to activate RTSP on two VLANs, 3 and 100, we are going to unite two new Alteon 2424-SSL.
Can I leave in the rest of VLANs of the switchs PVSTP +? Do as I can configure this mixed configuration? The switchs are: Catalyst 6506 With 720-3B. Catalyst WS-C3750G-48TS and Catalyst WS-C3750G-24TS
n.nandrekar Wed, 06/25/2008 - 05:01
  • Silver, 250 points or more
Hi!
You cannot run mixed mode. The spanning tree mode affects the mode of the entire chassis.
Further you cannot have pure RSTP on 6500. 6500 supports,
Ferrari(config)#spanning-tree mode ?
mst Multiple spanning tree mode
pvst Per-Vlan spanning tree mode
rapid-pvst Per-Vlan rapid spanning tree mode
So you can either run rapid-pvst, or if you dont want volans 3 & 100 to have different spanning tree instances, you can run mst and combine them in a single instance.
Niranjan
(pls rate helpful posts)
