BARS 4.0.9 on 4.1(3)ES111
Jun 25th, 2008
we recently had a failure in our cluster installation and we had to manually rebuilt a Subscriber. After the rebuilt the Engineer originally missed to install BARS. We have now installed this too but unfortunately it seems our Hand Over Document from the original Installation has got the BackAdmin Private Password Phrase wrong.
Is there a way to "view" this somehow or do I have to uninstall the whole BARS from every Box ?
We are planning to install 4.1(3)SR7 next and BARS 4.0.13 is out so what would you recommend to do.
Is that account/password used for anything else than BARS?
THX
Steff
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 06/25/2008 - 05:26
Hi Steff,
There is not a way to view this password but it can be reset using Admin Utility (C:\Program Files\Cisco\bin\AdminUtility.exe)
This tool should only be used during Off-Production Hours. This password is used for other tasks as shown in the attached link;
From this excellent Tech Note;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml
Hope this helps!
Rob
Steffen.Baier Wed, 06/25/2008 - 06:02
Hello Rob,
THX for your fast response. Can you confirm that this Tool will actually only reset the Backadmin Password and would not touch any other passwords.
The screenshots show multiple User Accounts but I am not 100% sure if they reflect the Backadmin Account.
Steffen
Rob Huffman Wed, 06/25/2008 - 07:56
Hi Steff,
This utility will sync the Passwords for all of these;
SQLSvc, CCMServiceRW, CCMService, CCMCDR and CCMUser
Hope this helps!
Rob
PS: If you are thinking of uninstalling BARS, it will only need to be removed from the Publisher :)
Steffen.Baier Thu, 06/26/2008 - 02:28
Hi Rob,
just the final confirmation by resetting the single password for SQLSvc I will reset the BARS BackAdmin Password ?
THX for your patience
Steff
Rob Huffman Thu, 06/26/2008 - 04:39
Hi Steff,
No worries my friend :) Yes, if you use the Admin Utility to sync the passwords BackAdmin will be reset (and usable for your project)
Hope this helps!
Rob
PS: Don't forget to run this in non-production hours.
