Routing between DP
Jun 25th, 2008
Afternoon guys!! Im having a nightmare at the moment trying to get a number i dial "1090" to be routed to a gateway, once at the gateway for it then to be translated into another number "2649" for this to be matched under a DP and sent back to the call manager. sounds simple but is giving me a mah00sive headache, the reason for me doing this, is to drop the call a PLAR one into our call centre queues. which when routing in between the partitions in CCM our CS solution doesnt like an therefore doesnt drop to our agents.
The config is below would be nice if anyone has a solution or another perspective on where im going wrong.
voice translation-rule 1090
rule 1 /1090/ /2639/
voice trainslation-profile Outbound_test
translate called 1090
Dial-peer voice 1090 voip
translation-profile incoming 1090
destination-pattern ....
progress_ind setup enable 3
no modem passthrough
voice-class codec 1000
voice-class h323 1
session target dns:etg-ccm02
incomfing called-number .
detmf-relay h245-alphanumeric
fax-relay ecm diable
ip qos dscp cs3 signalling
no vad
incoming called-number 1090
below is the debug of the DP:
*Jun 25 10:47:50.010: //-1/00B4A0362008/DPM/dpAssociateIncomingPeerCore:
Calling Number=3413, Called Number=1090, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1090
*Jun 25 10:47:50.014: //-1/00B4A0362008/DPM/dpAssociateIncomingPeerCore:
DR-VGW(config-dial-peer)#
*Jun 25 10:47:50.014: //-1/00B4A0362008/DPM/dpMatchPeersCore:
Calling Number=, Called Number=1090, Peer Info Type=DIALPEER_INFO_SPEECH
*Jun 25 10:47:50.018: //-1/00B4A0362008/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=1090
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Jun 25 10:47:50.018: //-1/00B4A0362008/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
gboulle Wed, 06/25/2008 - 04:01
you're dp are quite mixed. Separe outbound from inbound.
Also noticed that if you have an voip incoming leg et an voip outbound leg, it can only work with ip to ip gw with something like this :
voice service voip
hellspire69_2 Wed, 06/25/2008 - 04:10
Thanks for your response, I already had the allow-connections done actually, just didnt have a outbound Dp configured to route the call after it had been received inbound ~:)
