enterprise vs. consumer switch
companyflow
What are the drawbacks in your opinions of using a consumer-type switch(linksys, netgear) as a "lowest layer" switch. "Lowest layer" meaning that I have another switch connected to a fiber backbone and I would use this consumer switch to connect to that distribution switch. The consumer switch would be connected to a computer lab of 22 PCs.
Edison Ortiz
You may be facing compatibility issues when deploying certain switching features that aren't supported on those consumer switches.
For instance, you have to deploy a VoIP design with extensive QoS - you won't get the needed features from those switches.
Other designs can also present a challenge.
If you consider that computer lab a pure test network, then I don't see a problem using a consumer switch to extend network connectivity and it shouldn't harm the upper layer switches but they will offer quite limited services.
HTH,
__
Edison.
