Load balancing on ASA
Answered Question
Jun 25th, 2008
Can i load balance may traffic using single security appliance (ASA)
Thank YOu
Correct Answer by balsheikh about 8 years 7 months ago
Hi Gents,
but in this case ONLY one ISP is active at the time and the other is idle.
but if u require a load balance between two ISPs, I believe one more router needed to connect to the FW and configure a route-map for load balancing.
Correct Answer by a.alekseev about 8 years 7 months ago
Overall Rating: 5 (2 ratings)
shijomon scaria Wed, 06/25/2008 - 20:02
Suppose i have an ASA in my netowrk, can i terminate two ISPs on my appliance? Also those connetions should provide load balancing in an active-active manner, if one goes down other should carry the entire traffic.. Is it is possible, if so Which among the ASA 5500 series will support these features..?
Correct Answer
balsheikh Thu, 06/26/2008 - 10:12
Hi Gents,
