VSS with fabric enable card & server loadbalancing
Jun 25th, 2008
I would like to know as how VSS with fabric enable card differenciate with SUP 720 with fabic enable card ?
2) What are major advantage of using VSS with fabric enable card to VSS with non fabric enable line cards ?
3) How the server load balancing with NIC team works with VSS ( two 6513 chassis with VSS) as two different chassis is virtually consider as one ?
4) Is all fabric enable card supported in 6513 chassis with VSS ?
5) Does all fabric enable cards supported in all slot of 6513 chassis with VSS ?
