CCENT
Jun 25th, 2008
I have just completed the first two of the four courses that cisco networking academy provides for CCNA prep, should I be ready for the CCENT by now or am I missing any thing that will be covered in this exam? Is any one else going through the networking academy? And is the CCENT pretty simple?
rsvensson Wed, 06/25/2008 - 07:16
To be completely honest, the best way to determine if you are ready is to goto the certification page on Cisco.com and look at the Outline of the exam topics. Make sure that you feel confident in each of the topics and sub-topics. The topics will tell you exactly what to expect. If you feel inconfident in any area, try to lab it up (if you have the resources to do so), or study up on it as much as possible.
You never want to go into an exam thinking that you are not ready because it will be on your mind constantly and it may prove to be fatal on your score.
Here for the CCENT certification site:
http://www.cisco.com/web/learning/le3/current_exams/640-822.html
Good luck on your test and hope this helps,
--Richard
