Protect config on PIX515 from password removal attempts
Jun 25th, 2008
is it possible to have the PIX erase the running config if the password is removed using the (well known) special BIN file for that purpose? I know the routers can do this....
jdlampard Wed, 06/25/2008 - 19:41
Not sure. However, if you have such concerns then your problems are in the physical security arena first and foremost.
-JD
