how to add switchports into a VLAN on 877
Answered Question
Jun 25th, 2008
Hi all. I've got a Cisco 877 to replace our old shoddy ADSL router.
I want to connect it to our internal network so the PC's and server can use it as the Internet gateway.
Now obviously i'll need to configure an IP address for them to look at, but when I try to conigure an IP address on E0, I get the 'go away, you can give a switchport and IP address fool' message...
I can rememeber something about needing to create a VLAN, give it an IP address and assign the switch port to that VLAN, but, alas, I cant remember how to do it.
Can someone help?
Thanks!!
Correct Answer by Jason Fraioli about 8 years 8 months ago
If you use VLAN 1 as your interface VLAN, then you shouldn't have to do anything special to the access port. It should by default be a member of VLAN 1.
Make sure the port is a member of VLAN 1 by using 'switchport access vlan 1'
Overall Rating: 5 (1 ratings)
Jason Fraioli Wed, 06/25/2008 - 06:05
you'll need to issue the 'no switchport' command prior to attempting to put an IP address on that switchport.
davieshuw Wed, 06/25/2008 - 06:13
Ok, I get these choices, any reccomendations?
inetrtr(config-if)#no switchport ?
access Set access mode characteristics of the interface
mode Set trunking mode of the interface
priority Set 802.1p priorities
trunk Set trunking characteristics of the interface
voice Voice appliance attributes
andrew.butterworth Wed, 06/25/2008 - 06:15
Not on a 877 it doesn't.... The FastEthernet interfaces on the 877 are ONLY Layer-2 switchports - they can be trunks and Voice VLAN enabled access ports but they CAN'T be routed interfaces.
By default they are all assigned as access ports attached to VLAN 1 so you would need to create the VLAN SVI and assign an IP address to this:
interface VLAN 1
ip address 10.1.1.1 255.255.255.0
Andy
davieshuw Wed, 06/25/2008 - 06:19
Right and then simply make the relevant port (E0) a member of VLAN 1
Correct Answer
Jason Fraioli Wed, 06/25/2008 - 09:24
