Sending different voice calls to two different e1 channels? how?
Answered Question
Jun 25th, 2008
What I want to do is, when I call 1111 I want to send these calls from the first ten channel;
when I want to call 9999 I want it to use the channels from 10 to 30. Does it possible? Two dial peer
sends voice traffics from different e1 channels... How can this be implemented?
thx
Serial0/1/0:0 unassigned YES unset down down
Serial0/1/0:1 unassigned YES unset down down
Serial0/1/0:2 unassigned YES unset down down
Serial0/1/0:3 unassigned YES unset down down
Serial0/1/0:4 unassigned YES unset down down
Serial0/1/0:5 unassigned YES unset down down
Serial0/1/0:6 unassigned YES unset down down
Serial0/1/0:7 unassigned YES unset down down
Serial0/1/0:8 unassigned YES unset down down
Serial0/1/0:9 unassigned YES unset down down
Serial0/1/0:10 unassigned YES unset down down
Serial0/1/0:11 unassigned YES unset down down
Serial0/1/0:12 unassigned YES unset down down
Serial0/1/0:13 unassigned YES unset down down
Serial0/1/0:14 unassigned YES unset down down
Serial0/1/0:15 unassigned YES NVRAM up up
Serial0/1/0:16 unassigned YES unset down down
Serial0/1/0:17 unassigned YES unset down down
Serial0/1/0:18 unassigned YES unset down down
Serial0/1/0:19 unassigned YES unset down down
Serial0/1/0:20 unassigned YES unset down down
Serial0/1/0:21 unassigned YES unset down down
Serial0/1/0:22 unassigned YES unset down down
Serial0/1/0:23 unassigned YES unset down down
Serial0/1/0:24 unassigned YES unset down down
Serial0/1/0:25 unassigned YES unset down down
Serial0/1/0:26 unassigned YES unset down down
Serial0/1/0:27 unassigned YES unset down down
Serial0/1/0:28 unassigned YES unset down down
Serial0/1/0:29 unassigned YES unset down down
Serial0/1/0:30 unassigned YES unset down down
controller E1 0/1/0
pri-group timeslots 1-31
interface Serial0/1/0:15
no ip address
no ip proxy-arp
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
dial-peer voice 100 pots
destination-pattern 1111
port 0/1/0:15
dial-peer voice 101 pots
destination-pattern 9999
port 0/1/0:15
Correct Answer by paolo bevilacqua about 9 years 4 weeks ago
Trunk-group under controller listing the TS and reference the TG instead of port under DP.
Hope this helps, please rate pos if it does!
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 06/25/2008 - 06:33
  • Hall of Fame,
    Founding Member
Before entering the details of how it can be done, can you tell us why do you want to do this and what problem are you trying to solve ?
blackswans Wed, 06/25/2008 - 06:38
The other site wants this to route the calls to outside and inside. He says you must do that for his routing. thx
paolo bevilacqua Wed, 06/25/2008 - 06:45
  • Hall of Fame,
    Founding Member
Can you confirm with them that they need to route based on the channel number rather than called number on a PRI circuit? That is rather unusual in telecom.
However it is possible to configure trunk-group ranging B-channels on a single pri controller.
So I recommend you try to have them do a regular number-based routing before exploring this other route.
blackswans Wed, 06/25/2008 - 06:49
Actually they are giving access levels to these channels thats why they need this. So when I call 1111 it should go from the first ten channel. Do you have any config for that situation ?
thx
Correct Answer
paolo bevilacqua Wed, 06/25/2008 - 06:51
  • Hall of Fame,
    Founding Member
