Warning message
How to change the IP address for the switch?
Collin Clark Wed, 06/25/2008 - 06:38
  • Purple, 4500 points or more
Assuming that the IP address is assigned to vlan 1,
config t
int vlan 1
ip address [new ip address] [netmask]
As soon as you hit enter, you'll lose management connectivity, but you should be able to connect to the new address. If you're changing management networks, you'll want to double check gateway/connectivity before making the change.
Hope that helps.
Ibbywannit Wed, 06/25/2008 - 06:40
If you are running a Layer 3 switch with the appropriate IOS then to assign an IP address to a specific port you would run the
"no switchport" command.
