06-25-2008 07:44 AM
I've configured some HUM collectors. When the collector is a standard one (CPU, memory, utilization, etc.) I can see the associated graphs but when I define a new collector (i.e., incoming traffic) I can see the data in a table but I cannot see the graph.
What do I have to do in order to watch these graphs?
Thank you very much.
Solved! Go to Solution.
06-25-2008 11:03 AM
You should be able to use the Histo-Graph It portlet, and generate a graph for any polled object on your device. Is this not working?
06-25-2008 07:54 AM
Where are you looking that you do not see graphs (i.e. the portal or a report)?
06-25-2008 10:30 AM
I'm looking in the portal. I can see the icon for launching graphs related to standard collectors but not for the ones that I create ad-hoc.
06-25-2008 11:03 AM
05-04-2009 06:29 AM
OK, that works!
