Ciscoworks - Database Ad-hoc Retrieval
Answered Question
Jun 25th, 2008
I am trying to use the Ad-hoc Retrieval page on our Ciscoworks (LMS 2.6) implementation. I have been getting the failed login (bad username/password) message when attempt to pull table data.
I have tried the default (sa/c2kY2k) but I get the same results.
The /rmeng/orig/odbc.tmpl file contains a CWUID and CWPWD but they do not work (I'm assuming they are encrypted).
Any ideas or other password combinations for the database?
Correct Answer by Joe Clarke about 8 years 9 months ago
This tool is not supported for customer use. Changes to the database using this tool could require you to reinitialize your database, thus causing data loss.
That said, the database passwords are random in LMS 2.6. You can use the NMSROOT/bin/dbpasswd.pl utility to set the database password to a known value.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 06/25/2008 - 08:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
